jeg har tidligere sagt og argumentert for hva en kondensator gjør og IKKE gjør i et bilstereo system, men faktisk en "glede" å finne berømheter som mener det samme som meg -eller omvendt... (hva kom først? høna eller egget?)
Dette fant jeg i andre forum men de som har tid kan spore opp nøyaktig kilde eventuel... alt er på engelsk men ganske greit lektur egentlig -en fordel med et minimum av teknisk kunnskap for å forstå det helle. Ellers er vel bare å spørre, tross alt vi kan ganske mye her til lands også...
The following is a series of excepts from CarSound written by Richard Clark which examines capacitors in every detail. Read first...then ask questions.
Lesson 1
Ok “powertrip” how about we have a discussion in basic electrical theory? At the end of this thread you should be the one that can explain to the world that according to ohms law it is impossible for these things to do any good. That is of course if you can admit that they do obey ohms law. We will do this a little at a time so how about you humor me and stick to my questions. We will do them a couple at a time so everyone can follow along. Let’s do a little calculation. Suppose we have a resistor that is .017 ohms (seventeen milliohms). I think that is what you say the ESR of the giant caps is.
The ones I have seen have measured higher but I will give you the benefit of the doubt. According to ohms law how many volts are dropped across .017 ohms if 100 amps of current are flowing? How about if we up the current to 300 amps? Let’s establish the answers to these questions before we go any farther. If we can't agree on the answer to this there is no hope we will ever get to the truth.
Lesson 2
Thanks David you are exactly right. If anyone wants this explained please ask David to clarify it. If everyone is going to follow this and understand fully the final conclusion it is important that no one miss any steps. There will be about ten lessons. Since power trip has left the building we will continue with the rest of the class. ESR stands for equivalent series resistance. This means exactly what it sounds like. It means that if we have a source of voltage it will behave exactly as if it has a resistor of the same value in series with its output. An amplifier has ESR, a power supply has ESR, a battery has ESR, and yes, a cap has ESR. Components have ESR’s because we do not have perfect conductors to make things from.
And now for the homework. Last night we learned that if 100 amps flows through .017 ohms there will be a voltage drop of 1.7 volts. And if the amp flow increases to 300 amps the voltage drop will increase to 5.1 volts.
For the sake of theory only let’s say we have built the largest cap in the universe and it has billions and billions of Farads. Its plates are made of a newly discovered material we'll call unobtanium. This new material has no resistance therefore our super cap has an ESR of ZERO ohms. We then charge the capacitor to 14.2 volts. We then place a resistor with a value of .017 ohms in series with one of the terminals of this cap. The question is: If we place a load that draws 100 amps from this cap what will the resulting voltage be on the load side of the resistor? What will the voltage be on the cap side of the resistor? What about if we increase the load to 300 amps? What will the voltages be on each side of the resistor?
Lesson 3
Ok now that we have studied ESR and understand what it is and it’s effect on the working of a circuit we will move on to another subject. But don’t forget about ESR as it is one of the important final building blocks in our search for truth about caps and we will come back to it. Today we will review the important concepts about total energy storage in a device like a cap. This has been covered in earlier posts (and I will say quite correctly) but I am going to expand on it as well as reiterate it for those who did not get to read it. Besides, I think I can simplify it a little.
In electronics, we measure power in watts. Wattage tells us how much work a device can do. But a wattage rating does not tell us anything about how long we can sustain that work. When we add the element of time to our wattage, we use a value we call Joules. A joule is a watt second. This means that one Joule of energy can provide a watt for a second. Ten joules can provide a watt for ten seconds or ten watts for one second or five watts for two seconds one hundred watts for a tenth of a second, and so on.
The formula for determining the total joules stored in a capacitor is very simple. We take one half the capacitor’s value in farads and multiply it times the squared charge voltage. For example a one farad cap charged to 14 volts would be .5 X (14x14) = 98 or .5 X 196 = 98 Joules. A 20 farad cap charged to 14 volts would be 10 X (14x14) = 1960 Joules.
There is a very important concept to understand about energy storage. A capacitor actually stores electricity.
Batteries don’t. Batteries have the potential to produce electricity by means of a chemical reaction but caps actually store electrons on their plates in the form of an electrostatic charge. In our next two lessons we will learn why this is important to know.
But first, the homework. This is a “think about it question”. We have learned that a Joule is a watt second. A Yellow top battery is rated at 65 amp hours. This means it can provide 65 amps for an hour. The question is how many Joules does this represent? Since this is a thought question, it would really help if whoever answers would show us your math.
Lesson 1
Lesson 2
Lesson 3
