MotusLab - DSP AWGPlus
  • MotusLab - DSP AWGPlus
    Faktisk noen her som har prøvd eller vært i bort denne go saken her?
    DSP for bilstereo , styres av PC.. Passer utmerket til biler med fabrikk montert stereo...
    Plug-in-play
    http://www.motuslab.com/
    http://www.motuslab.com/en/pagine-di-esempio.html
    Spec:
    AGW Plus and AGW Ligth are both available for Italian Market.
    AGW Plus only for foreign markets.
    Our USA distributor is ORCA Design from Camarillo, CA.
    AGWPlus got an audio DSP with the following features:
    - DAC 24bit, 192Khz Burr Brown
    - 115dB SNR, under request is available a 123dB version
    - 4.2 Vrms with analog volume control (no digital scaling is present on our system)
    - 31 bands Graphic Equalizer
    - 5 Bands Parametric Equalizer on each channel
    - Digital CrossOver (LP,HP,BP) on each channel with slope from 6dB/octave up to 36dB/octave
    - Delays (up to 3,4 meters)
    - Phase inversion
    - Phase adjustment (only for sub)
    - Output level setup on each channel
    Under request a SPDIF/TOSLINK output is available
    All other settings (Volume, Balance, Fade, Bass, treble and Graphic Eq.) are controlled by Head Unit or steering wheel comands.
    AGWPlus is an AudioGateway with OUT and INPUT capabilities. INPUT means to fully control IPOD or USB Key by the original Head Unit. These functionalities can be added on the product on aftersales too. It something like a PC you buy the mainboard now, and some time later you can add new board for to have new functionalities. INPUT capabilities from IPOD is under test in this moment. It will be released for USA market close to next CES (as well as AGWLigth). The price as not been defined yet but it could be around $220-$250 for IPOD only, $300 for USB +IPOD.
    Some picture can be found at this link http://www.drivehq.com/folder/p6359750/025916389.aspx
    Sorry for this intrusion, for any other information contact us at info@motuslab.com
    Link hentet fra: http://www.e90post.com/forums/showthread.php?t=309245
    Demo video : http://www.youtube.com/user/MotusLab#p/u/4/gNy0H87wMgY
    Hørt prisen her for AWG Plus er $2000,-
