2 set 1000kr
Spl Dynamics HF-6.1 nya i kartong. (finns diskanter och filter från massive audio som följer med)
http://www.spldynamics.fi/products/s.../hf-6_1-e.html
Generator från Audi 100 C4 2.6 V6a 120ah 300kr
Generator från Ford Mondeo 300kr
Ground Zero GZDF 300-GOLD ( http://www.ground-zero-audio.com/en/...df300gold.html )
799kr/st Finns 2 förpackningar ( Nytt i kartong )
Ground Zero GZHA 5125 https://www.fanaticaudio.com/shop/po...-gzha-5125xii/
Endast uppackat och provat.
2500kr
Har 2st
Phoenix Gold Xenon X200.2
RMS Power @ 4 ohms 200 watts x 2 channels
RMS Power @ 2 ohms 200 watts x 2 channels
RMS Power @ 1 ohm 200 watts x 2 channels
Bridged RMS Power 400 watts x 1 channels
https://www.sonicelectronix.com/item...on-X200.2.html
1200kr /st
Phoenix Gold Xenon X1200.1
RMS Power @ 4 ohms 1200 watts x 1 channels
RMS Power @ 2 ohms 1200 watts x 1 channels
RMS Power @ 1 ohm 1200 watts x 1 channels
Bridged RMS Power Not Bridgeable
https://www.sonicelectronix.com/item...n-X1200.1.html
4000kr
Eller alla för 5500kr
Har fått tag i 2st 5ch klass ab steg.
Dessa säljes självklart då jag ej är i behov av dessa.
Pris : 1000kr/steg, dessa är nya i kartong.
Info : https://www.crutchfield.com/S-vIF1Yu...-MRA-F350.html
5-channel Digital Theater amplifier
50 watts RMS x 5 at 4 ohms
Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
optical digital input (requires optical cable)
all amplifier functions controlled by touchscreen of your compatible Alpine receiver (no built-in controls)
connects to compatible Alpine navigation systems, including:
IVA-D100, IVA-D105, IVA-D106, IVA-D300, IVA-D310, IVA-D900, IVA-D901, IVA-W200, IVA-W205, IVA-W505, DVA-9860, DVA-9861 and DVA-9965.
MOSFET power supply
CEA-2006 compliant
Bass Engine® features:
variable center-channel high-pass crossover (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
variable front left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
variable rear left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
variable subsonic filter (20-50 Hz in 1/6 octave steps, 6/12/18/24 dB per octave)
subwoofer phase control (0/180 degrees)
time correction adjustment (0-20 mSec in 0.1 mSec increments)
17-band parametric EQ (five bands for front, rear, and center, two bands for sub channel)
STAR Topology (minimizes internal noise and prevents ground interference)
detachable front cover
blue power LED
fuse rating: 20A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
DLS Reference 100a 800kr
DLS Reference 200a 1000kr
(http://www.dls.se/econtent/files/34/refsva.pdf)
DLS D1000, trasigt. Vet ej orsak.
500kr
Paketpris på alla DLS 2000kr
Har ett gäng kartonger med CDT liggandes.
2-3" mellan
4" kit
5.25" kit
6.5" mid/sub
6x9" kit
8" sub
Ska sälja en del av de så skriv i pm/mail (henrik (snabelgurka)henkz.se) vad du/ni är intresserade av så kollar jag/fotar och återkommer.
Komplett 3-vägs orangea ES serien.
ES07
ES04
ES01
ES300 (tror jag)
http://img.audiomania.ru/pics/goods/big/cdt_es-07.jpg
http://www.woofersetc.com/media/cata...fb8d27136e95/5
http://www.woofersetc.com/media/cata.../5/75373_4.jpg
https://http2.mlstatic.com/crossover-competition-3-vi
http://lightav.com/car/cdt/ES073.gif
Mid-woofer: Cast Alloy 7" Fiber Fabric Kevlar cone
Midrange: Cast Alloy 4" Fiber Fabric Kevlar cone
ES-300CC "Transient Optimized" Mid E.Q. 3-way xover
E.Q. 3-way xover.
Tweeter: ES-01 deluxe extended range 1” silk tweeter.
Power handling: 280 watt RMS @ 100Hz High Pass
Frequency response: 60-20kHz
Sensitivity: 92.3 dB.
Impedance: 4 Ohm
Pris ; 5000kr
6x9" kit
Cl-69x
(oanvänt i kartong)
http://www.woofersetc.com/p-3078-cl-...nt-system.html
Pris : 1000kr
QES680 x4
Oanvända i plastade kartonger
https://www.amazon.com/6-8-Audio-QES...ot_top?ie=UTF8
Pris ; 2500kr /par
ES-800 SQ 2st
Enbart uppackade och provmonterade i låda.
http://lightav.com/car/cdt/ES-SQ1000.jpg
Pris ; 1500kr /bas
HD2 2"
https://www.amazon.com/HD-2-CDT-Audi...ywords=cdt+hd2
1000kr
ES2 2"
https://www.cdtaudio.com/sep_compone...ters/es02c.php
1300kr
Allt finns i närheten av Sundsvall men kan självklart skickas mot fraktkostnad.
Enklast att komma i kontakt med mig är på henrik(a)henkz.se den läses varje dag
