Gå tilbake   ¤¤ BILSTEREOFORUMET ¤¤ > Bilstereo > Generell prat
  #11
Gammel 30-11-2009, 11:48
DD-Henrik sin avatar
DD-Henrik DD-Henrik er offline
Medlem siden: Feb 2009
Meldinger: 1,953
DD-Henrik is on a distinguished road
DDC1b
Effekt RMS @ 4 Ohm 2 x 70 W
Effekt RMS @ 2 Ohm 2 x 100 W
Effekt RMS @ 4 Ohm Mono 1 x 200 W
Maks. Dynamisk Effekt 1 x 400 W
Dimensjoner - mm 244.5 B x 54.3 H x 200 L
Pris 2190,-
DDSS1
Effekt RMS @ 1 Ohm 1 x 750 W
Effekt RMS @ 2 Ohm 1 x 500 W
Dimensjoner - mm 175 B x 52.5 H x 230 L
Pris 4490,-
DDC4b
Effekt RMS @ 4 Ohm 4 x 60 W
Effekt RMS @ 2 Ohm 4 x 90 W
Effekt RMS @ 4 Ohm Mono 2 x 180 W
Maks. Dynamisk Effekt 2 x 400 W
Dimensjoner - mm 244.5 B x 54.3 H x 300 L
Pris 2990,-
overtatt av www.dynaBel.no.
  #12
Gammel 30-11-2009, 13:56
epifant sin avatar
epifant epifant er offline
Medlem siden: Mar 2007
Meldinger: 1,569
epifant is on a distinguished road
41hz AMP32 (nederst), 32 euro fra 41hz.com
- Excellent sound!
- Single 12V supply Operation (max 14.7V). Stabilized power not required.
- Works very well of a 12V battery
- Typically 0.05% THD+N @ 2x13W 4Ω, 14.5V
- 2x25W @ 4Ω, 10% THD+N
- 2x14W @ 8Ω, 10.0% THD+N
- High Efficiency: 88% @ 13.5W 8Ω, 81% @ 25W 4Ω
- Dynamic Range = 100dB
- High power supply rejection ratio
- Over-current protection shutdown
- Over-temperature protection shutdown
- Turn-on and Turn-off pop suppression
- Perfect companion for a portable CD/MD/MP3 player
41hz AMP9, 65 euro fra 41hz.com
- Output 4x60W at low distortion, 4x100W peak
- Suitable for low impedance loads, 4 x 2 ohms 12V typical
- Outputs can be paralleled for even higher outputs into very low impedance loads
- Mostly hole mounted components. Relatively low component count.
- 35A rectifier on board
- Board size 50 x 160 mm
- Height 60 mm with 3 x 15.000 uF 35V bulk capacitors for up to 27V supplies (standard model)
- Low profile version 30 mm with 3 x 12.000 uF 16V capacitors for 12V supplies
Sist endret av epifant; 30-11-2009 kl 15:07.
  #13
Gammel 30-11-2009, 14:13
Miniboom Miniboom er offline
Medlem siden: Dec 2008
Meldinger: 2,116
Miniboom is on a distinguished road
Opprinnelig postet av epifant Vis post
Hvordan er lyden fra denne, noen som vet? "Klasse T", eller?
Bare lurer på om den egner seg for noe annet enn >100hz, eller veldig lavt volum, siden jeg ikke helt ser potensialet for noe særlig strømgjennomgang her. :P
  #14
Gammel 30-11-2009, 15:10
epifant sin avatar
Meldinger: 1,569
Vet ikke hvordan de låter nei. MEN to AMP9 kan visstnok paralellkobles til 2x120w, og da begynner det jo å likne på noe.
Rettet forresten posten min ettersom man kan bruke den minste AMP32-versjonen. Den store "glattelytten" trengs ikke ved likestrøm har jeg lest.
  #15
Gammel 30-11-2009, 15:33
r3mark sin avatar
r3mark r3mark er offline
Medlem siden: Oct 2007
Meldinger: 744
r3mark is on a distinguished road
10% distortion er jo hyggelige tall å jobbe med ;P
Roar Sørlie
Tlf 90127075
  #16
Gammel 30-11-2009, 15:54
epifant sin avatar
Meldinger: 1,569
Ante meg at noen ville kommentere det ja
Den vil jo ikke gi 10% THD hele tiden, og om man aldri tyner den såpass hardt blir det heller aldri noe issue. 13 watt (0.05% THD+N @ 2x13W 4Ω, 14.5V) er faktisk en god del, spesielt i øvre mellomtone og diskantområdet. En annen ting er jo hvor hørbart XX% THD er ved kortere impulser. Sikkert frekvensavhengig riktignok, men jeg mener å ha lest at det er snakk om ganske høye tall. Jo kortere puls, jo mer forvrengning er akseptert. Jeg påstår slett ikke det er noen high end-sak dette her, men den vil nok kunne gi masse "krutt per krone". Den koster jo omtrent like mye som stor pizza + cola levert på døra...
  #17
Gammel 30-11-2009, 16:32
magnesmurf magnesmurf er offline
Medlem siden: Jun 2009
Meldinger: 195
magnesmurf is on a distinguished road
http://www.bilstereoforumet.no/showthread.php?t=7909
  #18
Gammel 30-11-2009, 17:07
Meldinger: 2,116
Opprinnelig postet av magnesmurf Vis post
Les min første post igjen! Hehe...
Jeg VET at det har vært spurt etter dette tidligere, men det ble en tråd fylt med mye pjatt og få faktiske forslag - i motsetning til hva denne har vært så langt, så la oss holde det slik.
  #19
Gammel 30-11-2009, 17:19
Soundboy Soundboy er offline
Medlem siden: Apr 2007
Meldinger: 612
Soundboy is on a distinguished road
Standard Genesis
Genesis Stereo60 & Stereo100 er små forsterkere å monteres over alt, men dok kanskje dyr i pris!
  #20
Gammel 30-11-2009, 17:23
dBcompaniet sin avatar
dBcompaniet dBcompaniet er offline
Meldinger: 1,301
dBcompaniet is on a distinguished road
CEA RMS Power : 2x 90W @ 2 Ohm, THD+N ≤1%
CEA RMS Power : 2x 60W @ 4 Ohm, THD+N ≤1%
CEA RMS Power : 1x 180W @ 4 Ohm, THD+N ≤1%
High pass x-over : 12dB/oct variable from 40 to 400Hz
Low pass x-over : 12dB/oct variable from 40 to 400Hz
Signal-to-Noise Ratio (1 watt) : > 80dB
THD+Noise (Distortion) (1 watt) : ≤ 1%
Frequency Response (±1dB) : 20Hz-30000Hz
Maximum Input Signal : 6V
Maximum Sensitivity : 100mV
Dimensions : 310 x 180 x 55mm
Add higher output and more dynamic response with this easy-to-install head unit power upgrade. The KTP-445 amplifies the head unit power output, resulting in a 150 percent power increase over the original power from the head unit’s built-in amplifier.
