Skal ha to Kenwood KFC-W3013 i en kasse.
Det jeg lurer på, hvilken diameter og lengde må jeg ha på røret før at det ikke skal bli helt toskete lyd? Og antal liter på kassa?
Takker for svar, hilsen en amatør innen kassebygging!
Spesifikasjoner:
Peak Input Power 1200W
Maximum Input Power 800W
Rated Input Power 400W
Woofer Cone material Injection P.P. Cone
Speaker Basket Steel
Speaker Surround High-roll urethane
Spider Type Super Linear Spider
Sensitivity 86dB/W/m
Frequency Response 39Hz ~ 300Hz
Subwoofer Impedance 4Ω x 1
Dimensions (W x H x D) 326 x 326 x 174.3mm
Mounting Depth 156.8mm
Mouting Hole Diameter Ø 279.3mm
Speaker Weight 6100gr
Weight of Magnet 1780gr
Subwoofer Parameters:
Nominal impedance (Z) 4Ω
DC resistance (Re) 3.4Ω
Resonant frequency (FSO) 31Hz
Mechanical Q factor (QMS) 11.864
Electrical Q factor (QES) 1.107
Total Q factor (QTS) 1.012
Voice coil inductance (LBM) 1.4mH
Voice coil diameter (d) 65mm
Force factor (BL) 9.8T/m
Peak excursion Xmax 13.8mm
Moving mass (MMS) 158.8gr.
Volume accoustic compliance (VAS) 62liter
Piston Area (SD) 0.052m²
Displacement 4448cc
Spesifikasjoner:
Displacement 4448cc
