noen som hartips
Specs of the TYPE SWR-3040
•System.....................................12" Subwoofer
•Power Handling....................1,000 watts Peak
•Power Handling......................300 watts RMS.
•Amplification (per speaker)..............................
Up to 300W RMS.
•Frequency Response................30Hz~1.5kHz
•Sensitivity....................................90 dB/W(1m)
•Impedance........................................ ...4 ohms
•D.C. Coil Resistance (Re).................4.0 ohms
•Inductance (Le) 1kHz/10kHz.....2.8mH/1.0mH
•Free Air Resonance (Fs).........................30Hz
•Equivalent Stiffness (Vas)..........................69l
•Sealed Box for Q=0.707...............0.85ft.3(24l)
•Mechanical Q (Qms)................................6.64
•Electrical Q (Qes).....................................0.35
•Total Q (Qts)............................................. 0.33
•Excursion (X max, X peak)....4.0mm, 16.0mm
•Cone Area (Sd)....................................511cm2
•Diaphragm Material..........Plastic Coated Pulp
•Magnet Weight, Material...............1.5kg(52oz)
Strontium Ferrite
•Voice Coil Diameter.........................75mm(3")
•Driver's Physical Volume (Front Mt.).........3.2l
•Weight Per Speaker..................5.9kg (13 lbs.)
Up to 300W RMS.
Strontium Ferrite
