tem lab poblemer?
  • tem lab poblemer?
    hei fikk hjem tem-lab utsyet i dag, men klarte å instalet det på enn kamerat sin pc men ikke min:/
    når jeg pøve å få statet det så komme det opp (*THE TERM-LAB USB KEY MUST BE ATTACHED TO THE COMPUTER BEFORE YOU CAN RUN THE PROGRAM,)
    noen som ha noe som helst peilling på det poblemet? h ikke så vanviti mye data kunskap nå det jeler sont no
    mvh
    http://audioforum.termpro.com/forum/12.html
      "I had this same problem a few weeks ago. All I had to do was unplug the USB cord from the laptop and plug it back in, then start up Termlab and the issue was solved. Guess it was just a bad USB connection."
      | http://Sundownaudio.no | http://stereovest.no |
