S: Mtx ta81001
  • S: Mtx ta81001
    Har ein MTX TA81001 til salgs.
    Hørte veldig mykje positivt om denne og tenkte å prøve denne, men nå som eg skal handle meg bolig må eg berre selge unna det eg kan selge. Kjipt men slik er det.
    Denne er kjøpt frå statene, som manufacture refurbuished. Det ligger ved papirer på at den er testa og godkjent. Sjå bilde.
    Har ikkje lyst til å selge, og setter derfor ein minimum pris på h.b.o 4000,-.
    Varen befinner seg i Trondheim fram til 30.05. Deretter blir den flytta til Stryn.
    Spec:
    •Thunder Super Amplifier
    •Prizm EFX: Selectable Lighting Color, or Pusate to Beat
    •Xtant Technologies Cooling: Thermal-Regulated, Turbo-Charged Intercooler
    •RMS Minimum Power Rating:
    ◦500 Watts x 1 Channel @ 4 Ohms (RMS)
    ◦1000 Watts x 1 Channel @ 2 Ohms (RMS)
    ◦1500 Watts x 1 Channel @ 1 Ohm (RMS)
    ◦3000 Watts x 1 Channel @ 1 Ohm ( Peak Power)
    •Wired EBC Remote Subwoofer Bass Level Control Included
    •CEA-2006 Compliant
    •Strappable with Another TA81001
    •Power and Protection LEDs
    •Parametric Bass Control:
    ◦-12 - +12 dB Bass Control
    ◦Variable Bass Control Frequency: 30 - 80 Hz
    ◦Variable Bass Control Q: 0.5 - 4.0
    •Onboard Crossover: LP (40 - 200 Hz), Sub (20 - 50 Hz)
    •Phase Control: 0° / 180°
    •Semi Unregulated MOSFET Power Supply
    •High or Low-level Input
    •Adjustable Input Sensitivity: 100mV - 1V / 1V - 10V
    •0 Gauge Power Connectors with Built-In 4 Gauge Capacitor Terminals
    •Wired Bass Remote Control Included
    •Frequency Response: 20 Hz - 200 Hz
    •Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
    •Amplifier Class: D
    •Number of Channels: 1 - Mono
    •THD at Rated RMS Power: 0.5%
    •Speaker Level Inputs: Yes
    •Built-in Crossover: Low-pass (LP)
    •Low-Pass Crossover Frequency: 40 - 200 Hz
    •Subsonic Filter: 20 - 50 Hz
    •Signal-to-Noise Ratio: 68 dB
    •Bass Boost: -12 - 12 dB
    •Bass/Gain Remote: Yes
    •Fan Cooled: Yes
    •Fuse Rating: 40A x 4
    Bump! Forsterkeren befinner seg i Stryn nå!
      Opp!(titegn)
        Opp!(titegn)
          Bump........ Er den for dyr?
            en slik en gikk vel for 8k her
              bump......................
