Focal 5H1 (5H3241R) mellomtoner selges
Hvis de ikke er verdt mere enn det, så kan jeg likegreit beholde de
Mounting Depth: 2.5"
Magnet Diameter: 3.5"
Mounting Diameter: 4.25"
Overall Diameter: 5"
Frequency Response: 65-4,000Hz
Impedance: 4 Ohms
25mm Voice Coil
60 Watt RMS Power Handling
Stamped Basket
Polyflex Cone (Paper and Polypropylene)
Rubber Surround
Rubber / Foam Dust Cap
Fs: 71,9 Hz
Re: 3, 1 ohms
Qes: 0, 68
Qms: 8
Qts: 0, 63
Dia: 10, 5 cm
Mms: 8, 5 g
Lvc: 0, 32 mH
Hbob: 11 mm
Hgap: 5 mm
Xmax: 3 mm
Sd: 86, 6 cm2
Vas: 6, 1 l
BL: 4, 2 N/AIt aint loud until it feels like your front speakers is giving you a bitchslap!
