Soundmagus monoblokk
    A switching amplifier or class-D amplifier is a electronic amplifier where the active devices (especially in the output stage) are operated in on/off mode (i.e., as switches). The term "Class-D" is often assumed to mean "digital" amplifier, which is not correct. The quantization of the output signal at the power stage can be controlled by either an analog signal or a digital signal, in the latter case you could argue that you have full digital amplificati
      Ok. Kicker SX1250 er digital etter hva jeg har skjønt?
      Ser på den soundstream forsterkeren, at den har oppgitt 2000w med <0,5%THD
      http://www.soundstream.com/amplifiers-picasso.htm
      Og f.eks. Clarion har oppgitt 1500W med <0,1%THD
      http://www.clarion.com/us/en/product...294762631.html
      Bedre lyd i Clarion, da?
      R-Design
