6-6,5" sub
  • 6-6,5" sub
    Hei,
    Noen som har erfaring med å sette 2 stk 6,5" sub i hattehylla? om d funker noe særlig?
    Må kanskje ta ut sub, Da bagasjerommet er blitt for liten når jeg har 12"sub med kasse.Og mangler kunnskap å bygge noe smart hehe..
    Eller eventuelt freeair sub mot seteryggen.
    Hva slags bil? To 6,5-tommere er ikke allverdens membranareale, som er relativt viktig med free air/IB. En eller to AE IB15 skal fungere suverent
    At verken prisen eller utseendet er spesielt imponerende trenger man ikke bekymre seg over, 4 ohms-modellen er spesialkonstruert for nettopp slik bruk i bil.
      At verken prisen eller utseendet er spesielt imponerende trenger man ikke bekymre seg over, disse er spesialkonstruert for nettopp slik bruk.
      Takk for svar er en 99 mod carisma sedan.
      Har du noe erfaring med de der da?
      edit: selges ikke i norge?
        Ikke personlig, men om du googler dem finner du veldig mye gode kritikker, f.eks. denne.
        I've used many subwoofers in this car in the past: Polk Momo, Infinity Kappa Perfect, Kappa Perfect VQ, Audiobahn flame Q (oh boy), RE XXX '05 model and many more for midbass duty This easily tops my chart as best overall. It's only downside is its spartan pro audio looks. The paper cone and foam surround are hand treated with a very sticky coat. The basket has an unatractive rubber ring. Overall this sub is pure function, there isn't a single part in its construction that is for show. While the paper is unimpressive it is light, stiff, not easily dented due to misuse or mechanical stress and handles mobile environment very well. The foam surround has very low resonance just like the cone. The rubber ring protects the surround and allows the sub to be rested on the front frame. The back of the sub is very tasteful, lots of venting, attractive spider and thin spokes.
        A+ for blending in with the midbass, virtually nonexistent motor noise, low resonance, upper extension, basically anything one would require from a driver in this application. I am truly impressed how the cheapest sub I ever bought was also the best performer. It shines in its transparency, I am perplexed just how well it dissapears. There is no distinct sound that would draw attention to its work, it has no hallow sound in the 80hz region like most subs 12 and over that i've tried. It is a live example that large diameter subs are not intrinsically sloppy, low end monsters, or slow, these are bogus remarks imo. I've come across none of these drawbacks.
        En annen fordel er at du slipper unna med langt mindre forsterkere; typisk 150 - 250 watt!
        EDIT: selges kun direkte fra Acoustic Elegance ja. Hadde ikke vært et sekund i tvil om å handle med dem
        EDIT 2: Mulig Dayton Titanic 15 ville fungert ok, 2 199,- fra Avshop.no
          1000w i 4ohm blir kanskje overkill da?
          Ser jo greie ut de der.. Noe å tenke på
            Nja, 1000 watt / 2 = 500 watt på hvert element om du kjøper to. Om vi for enkelhets skyld sier at "nødvendig" effekt er ca 250 watt vil du ha 3-6 dB headroom, noe som kan være greit. Alltid bra å ha litt reserver i bakhånd, men det er selvsagt forskjell på å nappe løken og dra den helt av
              For å gjøre en liten sammenlikning mellom hvor mye luft en 15-tommer kontra en 6-tommer flytter kan vi gange slaglengden (Xmax) med 2 (fordi Xmax bare regnes fra ett ytterpunkt til null) med membranarealet (Sd):
              - Tang Band W6-1139: 26 mm Xmax x 140 cm2 membranareale = 3640
              - AE IB15: 37 mm Xmax x 830 cm2 membranareale = 30710
              Én IB15 flytter altså mer luft enn åtte W6-1139. Åtte W6 koster over 4 000,-...
                Ahh.. Men litt enklere med bare 6,5" på hattehylla.
                Man får sjå
                  Om du har plass til 8x12" kan et par Tang Band W8Q være et alternativ. To W8Q tilsvarer ca. seks W6... Dynabel kan sikkert bestille disse for deg om du ikke vil handle selv fra Parts Express.
                    Trur jeg skal prøve å gå for en sub fast i seteryggen, noe mer liv i anlegget.. hehe..
                      2 slike i lukket kasser i hattehylla hadde nok gjort seg.
                      Eller bruke koffert som "kasse"
                      Free air muligheter
                      Skal jaggu sende mail eller plage Joakim med dette
                        Sikkert ikke dumt W8Q flytter faktisk nesten like mye luft som Seas Lotus 12. Er jo ålreit for stuehøyttalere med smal front også, kapasiteten til en 12-tommer fra bare 8 tommers bredde.
                          Lurer på åssen de ville ha fungert i hattehylle uten kasser eller noe slikt.
                            Når vi først er inne på det, hva definerer en free air sub? Den må jo nødvendigvis monteres i en baffel den også!?
                            Bmw e34 520:
                              Som i mange andre tilfeller er det T/S-parametrene som blir definisjonen egentlig. Å kalle elementet "free air" nytter jo ingenting om parametrene tilsier liten bassreflekskasse. Fs bør være relativt lav, Qts typisk mellom 0.5 og 0.7, Xmax så stor som mulig. Det morsomme er at det er ganske billig å konstruere elementer som egner seg bra til IB: Liten magnet, lang slaglengde og relativt tung membran. Mange billigelementer egner seg godt, bortsett fra begrenset Xmax i de aller fleste tilfeller.
                              Man kan få en viss pekepinn på hvordan elementet vil oppføre seg free air/IB ved å bruke WinISD eller liknende og sette kassevolumet til ~10 ganger Vas for eksempel.
